Need help for projector mount ceiling
I have been using a 6100 for the last one year which is ceiling mounted. My humble duggestion is avoid the ceiling mounting suggestion. In stead go for a shelf at the back of the room close to the ceiling and keep it inverted. Weather changes and at times cable pulls do change alignment which makes it a headache.
The cables would be concealed Hence pulls would be avoided. Please do suggest the ceiling mount is urgent.
Nikhil. The mount that I am using is from pioneer in mumbai. But note that the pj is made mostly of metal and even temperature changes could result in contraction / expansion
Can some one help me in buying projector pulldown screen 110inches 16.9 format or 120inches 4.3 format. Where cani buy in less price , madras or bangalore. Also I need 15m hdmi 1.4v cable. I checked deltapage website. Also I need to buy power cable for 15m for projector power adapter which is circular female 3 pin. Also 3feet ceiling or wall mount.
For any mount(projector, TV and speaker), one can buy from below vendor who makes it
Mangalam Electronics
# 103-A, Allaraju Muniswamappa Lane,
Thigalarpet, S.P. Road, Bangalore - 560 002.
Phone : +91 - 080 - 22108208 / 40914815
Centrex : Elect. 6312 / Cosmic : 3185
Mobile : +91- 94488 02723
I bought my wall mount for projector @ Rs.950/- Now I'm looking to buy 10x8 screen and cables
