Need Projector For Home Cinema <<Budget 30k-35K>>
SudipBasu
Kolkata
Hi fellow members,
As you can see my budget is very limited. So My options are also very limited. I already read many thread on this forum and little confused what should I do. All the quality projectors are out of my budget. I dont need 1080P resolution. 720P is sufficient. I think I have only 1 option in my hand right now. Egate P531 . Judging by the other members review on this forum, its not that good. But I think I am out of option. :sad:
Need valuable suggestion form you guys. :indifferent14:
My Budget is 30K to 35K
If you can extend ur budget a little bit more you can have
1) LG PB62G Projector (Rs. 41,200/-)
LG PB62G Projector - Buy LG PB62G Projector Online at best price in India : Flipkart.com
2) Dell M115HD Projector (Rs. 37,990/-)
Dell M115HD Projector - Buy Dell M115HD Projector Online at best price in India : Flipkart.com
Both are portable projectors, i would still check other options. As i am also looking in same budget.
Finally i have narrowed my choice to Acer 5380BD which costs about 38k from Amazon US. Or Optoma H181X which looks great, and costs about 42K.
still i am just making my mind :) Both are 720p HD 3D.
Today I went to a local Projector distributor. He suggest me BENQ TW523P for around 40K including tax.
Also he told me replacement bulb cost is around 12K.
If I go for Egate One then I can save almost 12K. I can invest that money to a good projector screen. Is there anyone who can vouch for the Egate one?
Where are you in India?
