Need Suggestion - BS Speakers
  • Thread starter Thread starter Deleted member 17547
  • Start date Start date
D
Guest
Hi All,
My bro have Sony's Home Theatre. We connected to my Yamaha NS8900 Tower speakers and it was sounding very gud.. far better than Sony's speakers.. So we are planning to get a pair of BS speakers.. Why BS, because of the size of tower speakers..
Can anyone suggest me any BS speaker in the range of 10-15K max. They will be used for music only.. Later we can buy an amp or receiver but as of now Sony will be used..
Thanks in advance..
Vikram
Hey thanks for the reply.. do you know any shop in delhi/gurgaon where we can audition them. There's one shop in Dwarka.. are these available there.?
What else you have at your store ?
We have the entire range of NAD Electronics and PSB Speakers with us for demo.
Apart from that we also have Supra Cables, Mitsuibishi Projectors, and Award Winning Violet 5.1 Wireless System.
We also deal in Denon, Defenitive Technologies, Sim2, Projection Design, Vogel's, Naim, d&b Audiotechnik, Millionaire Gallery, Focal, Legacy, Jadis, Fatman, Euromet, Marantz, Dune and Oppo.
Please give us a call to fix up an appointment.
Kool.. soon i'll be there... :licklips:
Will give u a call before coming... thanks..
Hi All,
Thanks in advance..
Vikram
PSB Alpha B1 or PSB Image B5/6
Hi Ashish,
in 10 - 15 K , i think only alpha B1 is possible or do you have nay demo/bargain deal for Image B5/B6 in 10-15 K...if yes I am very interested !
Hi Ashish,
Yes in that budget only Alpha B1 will come. But if the OP is willing to increase his budget then he has more options in the form of Image B5/B6.
Hi All,
Thanks in advance..
Vikram
Vikram
The best combination for bookshelf stereo music, will be Q Acoustics 2020 with either Marantz or Cambridge Stereo Amplifier or Marantz / Denon 5.1 AV Reciever...
Though Q Acoustics 1020 / 2020 and NAD-355 Stereo Amp is rated Best by What-HiFi UK, for 3years continuously now, so you can look at that option as well...
Priced @ Rs.15,900 MRP, this is available @
Swish Delhi - +919818788366
Gemini Traders - +919311155528
Q Acoustics - 2020
Vikram
Q Acoustics - 2020
Mridul, thanks for the reply.. would definitely come to your place for the auditions.. But right now i am looking for speakers only.. I'll get the Amp later...
Thanks,
Vikram
Thanks,
Vikram
Vikram
All of the above are my place... :)
But actually, i owe none of them... :p
They are all our company dealers...:clapping:
Get the speakers now to connect with your Sony amp, and later you can change your Receiver as well...
Vikram
Ooopsie.. i thought you own a showroom.. :)
