Need suggestions for 5.1 channel Home theatre set up.
Nickhill007
Pune
I have auditioned JAMO S606, Polk Audio RTI 5 series, Wharfedale 10.7 for my home theatre set up.
Need suggestions as to weather i should audition a few more brands?
I am considering the Denon 2000x Along with the Wharfedale 10.7 set up from the hifimart what are ur reviews about the same?
My room size is 26 feet X 15 feet . I would be using the set up for watching movies. should i consider Wharfadale 10.6 for the above room size?
What wires should i use to set up the system so many opinions on cheap and costly wires. I am cosidering to buy the DAC wires available online.
Your room is quite big. You could consider Wharf 10.7 or Polk RTiA7 whichever you liked more.
Try to audition Tannoy V4 also. May be even Boston Acoustics A360 if available.
For AVR, you can consider Denon 2000 or Yamaha 675. DAC cables are fine.
IS boston Acoustics A360 or Tannoy V4 in the same league as WHARF 10.7 or polk RTi7?
Heard the monitor 7 pro audio auanto 5. There is a very minor difference between these two but monitor 7 is 40k costlier than pro. Controlled bass and not so impressive mids. I believe monitor 9 is better
