Netflix Kodi addon installation issues in Zidoo X10
HDTV1080p
kolkata
As Zidoo X10 doesn't support Netflix, I tried to install it in Kodi using the Kodi Netflix plugin (https://github.com/CastagnaIT/plugin.video.netflix) but when I open the addon, it shows the following error:
The background services cannot be started due to this problem:
It was not possible to get the data from Widevine CryptoSession. Your system is not Widevine certified or you have a wrong Kodi version installed.
Is there any other means to watch Netflix in Zidoo X10?
