New Etios GD Please suggest Infotainment system
neel
Bought a new Toyota Etios GD that has only speakers and nothing else in the way of ICE. I would like to go for a comprehensive system that includes a reasonable amplifier, blutooth, GPS, touch screen and rear parking camera etc within a reasonable budget. I am a complete newbie in this area. Could anyone suggest kits and shops either in Bangalore or in Pondicherry. Thanks.
If you ditch the navigation, pioneer dvd1790 is a decent head unit. The cheapest hu with navigation is 40k plus. What is your budget?
Thanks nikhilstomer. I considered both pioneer dvd1790 and dvd 5790 and saw the demo pieces. The latter was priced at 23.5K with a 7" screen. Although I liked the screen size and features, somehow the bad access to usb and dvd tray as well as non-playability of standard mp4 and mkv format files killed this choice. Since my budget was under 20K, I settled down for a Chinese make called Seesonic that surprisingly sported a touch screen LED 7" display (pioneer ones are LCD) with better resolution than Pioneer 5790, could play mp4 and bearing most of the features such as BT etc. just for 6K! The set is now fitted and all the reported features working just fine.
