New model Onkyo HT-S4505
Rupam
Kolkata, Paschim Bango
Great News,
Onkyo India added new HTiB Model HT-S4505 which was earlier available in abroad.
ONKYO SIGHT & SOUND INDIA
Features >
2 Main improvements over 3400 and 3500 > included Powered Subwoofer and Audyssey Dynamic Volume (only 3400 has) and WRAT (Wide Range Amplifier Technology) (only available in 3500).
More Reasons to Choose an Onkyo Home Theater
If the four HDMI inputs, Audio Return Channel, convenient HDMI-linked set-up display, and Dolby TrueHD/DTS-HD Master Audio decoding havent already persuaded you, here are three more reasons to consider the HT-S4505 home theater. Firstly, Onkyos acclaimed WRAT (Wide Range Amplifier Technology)formerly a feature offered only on its higher-end modelsis now included. This noise-reducing technology contributes to exceptionally good audio performance across a wide dynamic range. Secondly, this model features Audyssey 2EQ, which calibrates the speakers and amp to match your rooms acoustics, thus perfecting the surround sound; and Audyssey Dynamic Volume, which lowers the volume of irritating commercials while making movie dialogue easier to hear. Thirdly, the active subwoofer is designed for high output and very low power consumption, rounding out a compact, powerful speaker set. All this (and much more) adds up to what we think is the best-value, best-performing, best-equipped home theater package around for the money.
HT-R558 5.1-Channel Home Theater Receiver
100 W/Ch (6 Ohms, 1 kHz, 1% THD, 1 Channel Driven, IEC);
120 W/Ch (6 Ohms, 1 kHz, 1% THD, 1 Channel Driven, JEITA)
HDMI Support for 3D, Audio Return Channel, DeepColor, x.v.Color, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
4 HDMI Inputs and 1 Output
Dolby TrueHD, DTS-HD Master Audio, Dolby Digital Plus, DTS-HD High-Resolution Audio Decoding
Direct Digital Connection of iPod/iPhone via Front-Panel USB Port
Discrete Output Stage Circuitry
Overlaid On-Screen Display (OSD) via HDMI
Audyssey 2EQ for Room Acoustic Correction
Audyssey Dynamic EQ for Loudness Correction
Audyssey Dynamic Volume to Maintain Optimal Listening Level and Dynamic Range
TI Burr-Brown 192 kHz/24-Bit DACs for All Channels
PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology for S/PDIF Audio
H.C.P.S. (High Current Power Supply) Massive High Power Transformer
Optimum Gain Volume Circuitry
Advanced 32-Bit Processing DSP Chip
4 DSP Modes for Gaming: Rock, Sports, Action, and RPG
Advanced Music Optimizer for Compressed Digital Music Files
Theater-Dimensional Virtual Surround Function
CinemaFILTER
Direct Mode
Double Bass Function
Non-Scaling Configuration
A-Form Listening Mode Memory
Mass Storage Class USB Memory Playback Capability
HDTV-Capable (720p/1080i) Component Video Switching (2 Inputs and 1 Output)
5 Composite Video Inputs (1 Front/4 Rear) and 2 Outputs
3 Digital Audio Inputs (2 Optical and 1 Coaxial)
6 Analog Audio Inputs (1 Front/5 Rear) and 1 Output
Speaker A/B Terminals
Color-Coded Speaker Terminals
Headphone Jack
Crossover Adjustment (40/50/60/70/80/90/100/120/150/200 Hz)
A/V Sync Control (Up to 400 ms at 48 kHz)
Tone Control (Bass/Treble) for Front L/R Channels
3-Mode Display Dimmer (Normal/Dim/Dimmer)
40 FM/AM Random Presets
RIHD (Remote Interactive over HDMI) for System Control
Compatible with RI (Remote Interactive) Dock for iPod/iPhone
Full-Function RI Remote Control
HTP-558 5.1-Channel Home Theater Speaker System
SKF-558 Full-Range Bass Reflex Front Speakers
8 cm Cone
Max. Input Power: 120 W
Gloss Finished
Wall-Mounting Capability
SKC-391C Full-Range Acoustic Suspension Center Speaker
8 cm Cone x 2
Gloss Finished
Magnetically Shielded
SKR-558 Full-Range Bass Reflex Surround Speakers
8 cm Cone
Gloss Finished
Note: All speakers feature an impedance of 6 ohms and color-coded speaker terminals.
SKW-558 Bass Reflex Powered Subwoofer
16 cm Cone
Max. Output Power: 80 W (Minimum Continuous Power, 4 Ohms, 100 Hz, IEC)
Gloss Finished
Down-Firing
GENERAL SPECIFICATIONS
A/V RECEIVER
Power Output: 100 W/Ch (6 Ohms, 1 kHz, 1% THD, 1 Channel Driven, IEC)
Frequency Response: 5 Hz100 kHz/+1 dB, -3 dB (DSP Bypass)
Dimensions (W x H x D): 435 x 150 x 318 mm
Weight: 7.8 kg
SPEAKER SYSTEM
Frequency Response:
Front 80 Hz20 kHz
Center 80 Hz20 kHz
Surround 80 Hz20 kHz
Subwoofer 27 Hz150 Hz
Front 101 x 175 x 116 mm
Center 240 x 102 x 121 mm
Surround 101 x 175 x 116 mm
Subwoofer 211 x 425 x 391 mm
Weight:
Front 0.7 kg
Center 1.3 kg
Surround 0.7 kg
Subwoofer 6.1 kg
Price around 35000/-
Any one has demoed this particular model?
Hi Rupam, its a nice info.
Where did you find the price?
I couldn't find the price in online stores and also inform from which store I can get it...
Have any one auditioned this model? could you share your reviews?
Does this model has heating problems like 3400? how does this scores when compared with denon 1312?
Thanks,
Did you take audition? how it fared in audition when compared to others?
Im planning to buy this one, so share your experience and it will help me :)
Bought HTR 558B with SKS HT 528B speaker package @ 37K. These speakers have Onkyo name on them and looks like a better built one.
When was this model launched? its not available in reliance digital and croma in chennai. i guess only onkyo dealer in chennai has the stock.
The Onkyo 4505 is a recently launched model. So, its availability may be limited to their Authorised Dealers. Please check with the Onkyo Dealer at Chennai. I think its in Teynampet.
Huh.... here is the address:
ONKYO
#49, Kasturi Rangan Road,
Alwarpet,
Chennai-600 018.
Tel:044 - 2467 1921, 4211 1648, 4211 1649, 4205 9044
Fax:4200 0094
Mobile:98410 62201, 98417 21137
[email protected]
Ask them through phone whether the 4505 is available with them or not. Then go for the audition. Also take a look at Yamaha HTs.
Read that onkyo receivers are prone to over heating. Do this model over heat? Does this have any effect in the life/quality of receiver?
