New posts at top
dichkaun
Hi admnis,
Is it possible to configure this forum so that the new posts in a thread come at the top, rather than at the bottom.
To read posts at the bottom it is a pain scrolling down to the end of the page.
Please try the following :
The setting need to be like this in control panel
Control panel-->edit options-->thread display mode-->Linear -Newest first
Please set it up like this and viola there you have it,the latest on top of the page and older in the bottom !!
By the way what happened buddy with your terrace Speaker ?? no news on that !
Regards.
Excellent. Works perfectly.
I am looking at the possibility of covering a small portion of the terrace (for a swing). Once I do that, then I can use any speakers. Don't really need an outdoor ones. Hence, the decision is on the hold.
Thanks for asking.
Good to know it helped !!
IC ok then best of the luck with the new project !! let us know how it progresses !!
Regards.
