Norge new millennium mark II
sgautam
Nellore
Dear friends, please share your experiences on the above speakers, my friend decided to buy a Norge 1000 and needs advise for the speakers too. He prefers to buy the speakers also from Norge. Is it a good pairing, the cost quoted was 12.5k for amp and around 15k for speakers. Are there any other options at that budget which can be sourced thru net. Kindly contribute, thanks in advance
Taga harmony bookshelf speakers are available on HiFiMART at discount. worth to look at
But need to check how well they pair with Norge
Sonodyne bookshelf speakers are good with Norge but lacking bit on low frequencies
Thanks a lot, not sure of Taga given very little info, my friend may not like to take a chance
I am considering the Pioneer BS-22 Andrew Jones. Reviews are good and its supposed to have decent lowend Even though the Woofer is only 4". Suggest you check it out tool.
Pioneer SP-BS22 might be a better choice compared to Norge Millenium.
I have heard both so I am quite confident.
Do anyone using Norge Millennium Mark II speaker ??
I thought of giving it a try (costing 15500) any warning before taking that risk..
