Onkyo TX-NR609 or TX-NR708
alkit
Johannesburg
I'm looking to purchase a new Onkyo AV receiver.
I can either get the TX-NR609 or the TX-NR708.
But each have features that I will loose out on if I go for the other, they are as follows:
1) The TX-NR708 is rated around 10W/channel (at 8 ohms) higher than the TX-NR609
2) The TX-NR708 has a much worse video up-converter than the TX-NR609. The TX-NR708 has the Faroudja DCDi cinema chipset, while the TX-NR609 has a Marvell Qdeo chip.
3) The TX-NR708 is available now. I have to wait 4 weeks for the TX-NR609
4) Price-wise, they will be equal where I live
I play all my video from my PC using avi files, mkv files and blue-ray. All these things are played out of my HDMI cable from my PC, so I think the software on my PC is doing the up-scaling anyway on the lower quality videos.
But, on the other hand, if I decide to hook up my SD def TV to my receiver one day, surely the TX-NR609 will give me far better video clarity.
So between all these points, its a real toss-up. Does anyone have advice which to go for, is the up-scaler really going to impact a lot, will the extra 10W impact the sound?
Thanks a ton!
If u have time, would advice waiting until some hands-on review of the 609 are out before taking the pick....u probably know how dynamic this particular market is. Previous performances dont ALWAYS guarantee a successful product in the succeeding years,so better be safe than sorry IMHO.
+1 to imhran ,but 609 has marvell chip video processing which is lastest processing,i dont think 10w/chn will make a big impact,wait for 609 to arrive mate.
Now that the 609 is available I'd go with it. The video chip in the 708 (and 608) has stutter problems with slow sources if you have a plasma screen, and sometimes color conversion problems as well.
cheers
JD
<a href="http://home-theater-audio.net/onkyo-tx-nr609-review/onkyo-tx-nr609-review" target="_top">Onkyo TX-NR609 Review</a>
Looking at the specs and reviews it seems to a very good AVR. Will audtion for a friend who wants to build a HT. Which speakers pair well with this - anyone auditioned?
