Paradigm CT100 or Klipsch HD Theater 500 ?
neo_49
MAHARASHTRA,INDIA
Dear friends for one of my friend i m searching good speaker package , local av dealer recommended this two package ,any comments on this choice pls.
room size approx 250 sqf
receiver denon 1612
REGARDS
Ct 100 or 110 ? For the price you are going to spend on these HTIBs , you can slowly build a decent 5.1 setup.
I have used the older version of Cinema 110 CT , they are pretty good. But odd shaped speakers , hard to wall mount or find stands for the L&R.
Is that the final price on HDT 500 ? Online reviews are very good, but I'd recommend you to listen to both and decide.
