Philips BDP2700 - is it a good buy?
If you are looking for a cheap BD player you can go for LG BD550. It would be priced around 5.5K to 6K. The main advantage with LG is it would play mkv files through USB and NTFS format is supported. However my advice would be not to buy a BD player which would only play region C BR discs. Better to get a Region A player where more titles are available or still go for a BD player which can be modded to play all discs.
