Vashista,
I think if you get it for Rs.19,500/- you should grab it with wide open arms. You won't regret this buy. This will be your last head unit. You will not change it after listening to it.
All,
Here are some -ve points after using it for about a week.
(1) the lever below the Multi-control knob is not that good idea. Even though I'm gentle with that, I can not expect a friend/wife/son on the front seat, to be. It is prone to be used without care and it might break. I have to be extra careful with that.
(2) I need a remote handy all the time, if I have to pause the song - that's too bad. I think a play+pause button is very important to any HU (after driving for a looong distance with lot of toll booth on the way).
I'll post the close up snap of it later as asked by Kittu.
Here is a better one..
