Pioneer PD-4100
chris05gto
WV
Hi, I just bought a pioneer pd-4100, it was suppose to have worked when shipped. When I tried it out it would not, I heard something loose inside so I opened the case and found this clear round piece. What is it and where does it go? And would it keep the cd player from working?
Thanks, Chris
Thanks, Chris
http://repairfaq.cis.upenn.edu/Misc/Blu-ray/site1/ps3diode-images/kes400ao-t.jpg
Looks like your CD player's objective lens came off. Your CD player won't work unless you repair it's optical pickup.
Thanks, Chris
Yes, the lens has fallen off. Try fixing it back on the laser transport ensuring that the lens stays clear. If it does not work, then you'd have to replace the laser transport. I think your player uses the PWY1010 Laser Transport.
