Planning to get a Grandview screen - motorized or fixed frame?
trivisingh
Hi guys,
I am planning to go for a 110" Grandview screen to go along with my EPSON TW8100, just not sure whether it should be motorized or fixed frame. The screen will cover a window and I might need some daylight in the room from time to time. That's why I am leaning a bit towards the motorized screen but my only worry is - will the screen be rigid enough to not show any ripples?
Also what should be the approximate cost for a 110" Grandview screen and also a good dealer in Mumbai for the same?
If the room is dedicated for entertainment then a fixed screen will be good idea otherwise motorized is much better.
If there is no daylight in the room then it should not be much of a problem as such natural light can be obtained in other rooms or even when we are on the move.
The ripples should not be a problem if handled well and as long as it is branded like Grandview.
On the other hand screen will shake some what if it is not around 6 feet away from ceiling fan.
V.
Dedicated Home Theater Room- You have a couple of options
1) Fixed Frame
2) Curved Fixed Frame
Multipurpose room- You have several Options
1) Manual Pull Down Screen
2) Motorized Screen
3) Tab Tensioned Motorized Screen
I have a manual pull down grand view 120" screen. There is a slight ripple problem. On closer analyses I found that installer didn't put it absolutely straight. So quality of installer is very important. If you can go in for fixed, nothing like it.
Thanks for the input guys, I think I will go along with the fixed frame screen. But I am confused as to the pricing of the GrandView screens. I have seen some guys getting a quote of around 12k for a 120" screen whereas the guy at AV Vision is quoting me a price of around 39k for a fixed frame GrandView screen. Could you guys confirm as to the actual price of a GrandView screen and from where I can get the best deal in Mumbai.
I have the exact same problem!
Any update on latest Grandview screen prices?
I am also looking for 120" CNV servies
I am quoted Rs. 16000 incl Tax and Shipping
The following price list may be helpful. Also see if you can just paint the wall with cream white which saves many bucks.
Source: http://www.deltapage.com/list/projectors.pdf
Projector screen price list -MW 4:3 Sizes NETT
1 Projector screen MW Tripod with stand 84 inch ( 6*4) 3,450
2 Projector screen MW Tripod with stand 100 Inch (7*5) 4,050
3 Projector screen MW Tripod with stand 120 inch (8*6) 4,950
4 Projector screen wall mount instalock 84 inch ( 6*4) 2,650
5 Projector screen wall mount instalock 100 Inch (7*5) 3,350
6 Projector screen wall mount instalock 120 inch (8*6) 4,050
7 Projector screen wall mount instalock 150 inch (10*8 8,150
8 Projector motorized screen with remote 84 inch ( 6*4) 6,950
9 Projector motorized screen with remote 100 Inch (7*5) 8,150
10 Projector motorized screen with remote 120 inch (8*6) 8,450
11 Fixed frame screen 16:10 ratio 100 Inch (7*5) 11,750
12 Fixed frame screen 16:10 ratio 120 inch (8*6) 15,750
13 Projector ceiling kit- 3 feet ( high quality) 3- feet adjustabl 1140
14 Projector ceiling kit- 6 feet ( high quality) 6-feet adjustable 2050
15 projector ceiling kit rotating 90rotating 3- feet adjustabl 2950
16 VGA cable- 5 meter- high quality 5- meter 480
17 VGAcable -10 meter- high quality 10-meter 638
18 VGA cable- 15 meter- high quality 15-meter 925
19 Power cable-5 meter- high quality 5- meter 275
20 Power cable-10 meter- high quality 10-meter 410
21 Power cable- 10 meter- high quality 15-meter 690
22 HDMI cable- 1.8 meter male to male 1.8 -meter 350
23 HDMI cable- 3 meter male to male 3-meter 470
24 HDMi cable- 5 meter male to male 5- meter 650
25 Cadyce-CA HWS-wifi streamer HD 7300 10,000
26 Cadyce-CAWP-2.4GHz wifi presenter 2175 2900
27 Targus presenter mouse-AMP13AP 2100 2499
28 Targuspresener mouse- AMP09AP 2900 3499
29 Logic presenter mousse-R400 2835 3495
30 Logic presenter mousse-R800 4620 5695
I have a liberty grandview..I think grandview is a canadian company that gets their stuff manufactured in China..Liberty is an Indian company that has a JV with them...some such story..anyways there guys are based out of Hyderabad and have dealers in Bangalore. I got my 120 incher for around 14K last year. Its a manual pulldown and havent seen any ripples so far. But again I used my projector once in a month or once in two months.
I like the manual pull down coz fixed screen would mean lots of risk in terms of stuff falling on the screen..I have two young sons and cannot risk having a permanent screen:lol:
