Hello folks !
I had posted a thread in the forum a while back in which I had asked for help regarding speaker for my PC. Earlier on i was leaning towards Onkyo 3300 but now thanks to the valuable suggestions from the members and my search on this forum I have shortlisted the following amps-
Denon AVR-1911
Yamaha RX-V667
Pioneer VSX-1020-K
Now I am going to attach the amps to my PC as I want to make my PC the source of my music and movies. My usage wd be 50-50 for the Bluray print movies (downloaded
) and music.
I wanted to know if I can attach the PC to these amps with ease. I am planning to use the onboard sound. The motherboard is Gigabyte G41MT-S2P with on board built in analog sound.It has the usual three slots for jacks- one mike and two speaker ones.. It claims to give Hi-def 108dB signal to noise ratio BluRay audio playback. Do you think it would be possible to achieve that or would I have to invest some more in a sound card... Phew.. !! hate to see money evaporate
Also i had shortlisted the following speakers-
1. Energy Take Classic 5.1
2. Mirage Nanosat 5.1
3. Klipsch HD Theater 500
4. Wharfedale Movie star 70
5. Polk Audio RM85 5-Channel Home Theater System
Do you think it wd be a good enough system? I guess I wd be able to pull the system off within 30-35 k if I buy the components from Alfa, Mumbai.
Guys your suggestions wd be a big help in pointing me in the right direction. Thanks !!
Denon AVR-1911
Yamaha RX-V667
Pioneer VSX-1020-K
