This is my setup ...
Speakers -
1) Dali Ikon 6
2) Custom speakers made from 15" Fostex Laboratory Woofers, horn loaded drivers and horn tweeters
Amp/Receiver
1) Onkyo TX-SR705
2) Yamaha M-80/C-80 amp-preamp set
I listen to music off my Ipod touch. and DVDs are currently played off a moser baer via the 705. I am planning to add the ps3 and a 42/46inch Full HD plasma tv
I am not much of an audiophile but I do know that I prefer clean, balanced sound without any distortion at any volume level.
I need help/advice on a number of things...
1) I want to add another preamp to the mix... after a lot of thought I am considering the Acoustic Portrait NJ1 preamp... but is there any other good option within a budget of 30/40K ?
2) Can anyone give me the contact of a good and knowledgeable electrician in Bombay to whom I can take the Yamaha amp-preamp in case I have any issues
3) I listened to and loved the Fatman Carbon Ipod dock, but its an amp by itself... is there anyway I can use it as the source/pre in my setup? or should I opt for an external dac instead?
4) I have not yet hooked up the Dalis to the M-80. The Dalis are rated 150W [email protected] while the M-80 is 250W [email protected] ohms ... conservative... very conservative... but I so want to listen to the amp off the Dalis... its such a sweet and awesome amp. I just want to be sure I don't blow the speakers by pumping too much juice, any idea how I can do that? or should I just abandon the thought?
5) whats the best VFM way to soundproof my listening room?
Speakers -
1) Dali Ikon 6
Amp/Receiver
1) Onkyo TX-SR705
