Please help with Bookshelf designs - Tangbad W5-1611SAF
Wharfedale EVO 4.1 4.2 Speakers
rbalu72
Hyderabad
I have got hold of a pair of W5-1611SAF - 5" Full Range TB-Speakers and my intent originally was to have a FH build with these. Datasheet can be had from here
I am looking for a bookshelf design to house these drivers as I already built FH using Markaudio CHR70 drivers.
Can someone suggest?
aniruddha82
Pune
I don't know anything about FH but check if the below link is of any use for this purpose.
Download | Leonard Audio
keith_correa
15.5 liter enclosure with port 1.5" [inner dia.] x 2.3" [len.]. This is tuned to 50.4 Hz. All inside walls lined with open cell foam.
rbalu72
Hyderabad
Thanks Keith_correa, need a bit more detail of what size box i should make and if possible some links to look at a prototype/box design plan will help noobs like me :)
keith_correa
Box size is up to you provided you keep the inside volume = what I specified + volume displaced by port + volume displaced by driver inside the box - though the last 2 are not very critical. It is said that the golden ratio used for box dimensions are the most effective in reducing standing waves.
