Plz help..
mb_xpress
chd
HI
I m planning to renovate my room completely..
its 15'x15' roughly dimensions..
I plan to have a 40 " lcd and plan to have a speaker system with good quality such that can be cobined with the tv, or a music/dvd player/fm.. an all purpose speaker system, to play whatever i plan to connect to it..
So i request to pls suggest
1. a gud speaker system and
2. how i shud install them as i m renovating completely so shud i get them installed in the roof/wall permanently??
Budget 10-15k...
Thanks in advance..
You will need an avr to connect all the devices you mentioned. Your budget is too small for an avr+speaker combination. You can buy onkyo 3400 for around Rs. 25k. This combines an avr and 5.1 speakers system.
Thanks for the reply sir..
I checked out sony and panasonic hometheatre system and they fit into my budgt also.. Bith aprox 15k.. Shud i go for it and which one out of the 2.. Or plz suggest something better...
Thanks again...
