Polk TSX550T or Focal 726V
nattu
chennai
Hello Please help me in deciding the floorstanders,
AVR would be Marantz 6008.
Speakers Focal 726V or Polk TSX 550T..
Also should I add a power amplifier to fronts? My living room size is 14 X 14 feet.
Please help...
if its music... go for a good 2 channel integrated else if for movies then i would look at the focals but please audition before you buy
Please help...
They arent in the same price range, are they ? I think the Focals are more expensive than the Polks you have mentioned
If you have budget for the Focals, there are other speakers you can consider.
With the Marantz 6008, you shouldnt need a power amplifier for your room size
