polkaudio speakers or Wharfedale speakers
gr_babu
hi guys this is babu grom chennai, u guys help me out in choosing out the brand of speakers suitable for my onkyo tx-sr 504
should i go for
polk audio which consist of
monitor40 for left/right
monitor30 for surround
cs1 for centre
psw10 or psw12 for sub
or
should i go for Wharfedale speakers which consist of
diomand 9.1 as right/left
9.0 for surround
9 cs for centre
sw150 for sub
please suggest me the brand i should choose, i use it for 75% movies, 25% music or is there any other brand better than the two brands mentioned above, max budget is rs 40-45 k. please suggest.
I would suggest you carry your favourite DVD/CD and buy the one that sounds good to you.
Personally I prefer the Wharfedale series.
thx for ur suggestion sir,
actually even i had finalised the wharfedale speakers,but had little difficulty in finalising them, now i am clear, thx once again.
