Popping sound in Pioneer S-31W + Pioneer VSX 323
PGY
Hyderabad
Hi Everyone,
Am using a Pioneer VSX 323 and a Pioneer S-31W. The following are the devices i have connected.
Sat/cab - Through HDMI cable
TV - Through OFC
PS3 - Through HDMI cable
The subwoofer is frequently (once in a minute) make a popping sound and it has become extremely annoying. Its a brand New system i have used it for a day. When the installation guys came, they were testing with high volume, so i was unable to find out this problem.
The Popping sound is happening when the low frequency's stop suddenly and while changing the channels in the SAT/CABL. Initially i thought its happening because am changing the channels. I have the same problem even if i connect a Hard Drive to the TV. The cone will just 'pop' back into its default position.
Did any one have the same problem ?
Any ideas to fix ?
Hi Everyone,
TV - Through OFC
Any ideas to fix ?
try to connect the sub power to other power outlet possibly to other phase if u have 3 phase eb connection. ur electrician can help
Thanks Thampi and Karthi.
I will try to connect the sub in to a different outlet and check. if we have the same problem again do i have to change the sub or can i upgrade/replace the sub to fix it ?
If i have to change the sub, could you please recommend a good one which is compatible with vsx 323.
Thanks Ch@ts,
Thanks for the link, Somebody came from the Pioneer & checked, they said the issue is with the Receiver, which is not the issue, i need to reiterate them about this firmware in the sub.
If i have an option to change the complete unit, can i go head with Onkyo s-3500 is it better than the pioneer ?
could some one help
great,Somebody came from the Pioneer & checked, they said the issue is with the Receiver, which is not the issue, i need to reiterate them about this firmware in the sub.
7KdHMP
Hi everyone,
Looks like i have to return the product and go with a different one.. Am stuck with Denon 1312, Onkyo 3500 and Yamaha YHT 299.
Could you please let me know which one i can go for..
I watch 80% movies and 20 % music.
Yamaha YHT 299 has better reviews than onkyo hts3500
slightly more powerful compared to onkyo and with 6 1/2' active sub
The issue is not with the Sub, the issue is with the AVR. I faced the same issue with Pioneer 323k and Polk sw110. I finally returned the AVR and upgraded to Denon x500.
