Portable CD/FM player with speakers
asliarun
Chicago
Dear forum members,
I'm looking for a portable CD and FM player with speakers (in other words, a compact boom-box) to be used by an elderly person. The system will be played in low (and at best moderate) volumes, should be reasonably compact, and should be portable between the various rooms of a house. It would also be nice if the system was easy to use (with a minimum number of buttons or knobs).
Can anyone recommend a player that meets these requirements, and that is reasonably well built (not too plasticky), and is able to deliver reasonable sound quality?
Thanks!
There are few models by philips starting with something AZ****
I think the basic model should be round 3K and others will more. Sony too has few models
but in same cost you can get a decent mini system. There are few chinese available too but not sure about quality. If you sacrifice CD player there is player from DAPIC with USB support. should be around 1.6K. Check out in Vijay sales & croma & big bazzar too.
