Post the components you are running
Just saw the link. It seems good for the price. :)
Also check other site like ebay alsso for other options like Kenwood,JVC etc which may come under the <8k category.
MY SIMPLE SETUP
CAR-- FORD FIGO 2011 JULY
FRONT--- PHD AF 6.1 KIT COMPONENTS
REAR ---- OEM SPEAKERS
HU ----- KENWOOD 4945SD
AMP----- JBL 1004e powering the fronts and sub
SUB ----- INFINITY REF 1064 IN SEALED ENCLOSURE 10INCH
SOUND QUALITY. PHD COMPONENTS ARE REALLY SINGING AND A GOOD MIDBASS.HIGH R REAL AND NO HARSHNESS.REALLY I LOVE THE SET UP.STILL WANT TO CHANGE THE AMP.
INSTALL AT POWERZONE.NEAT AND CLEAN INSTALL
OLD SETUP
HU----- JVC KW-R816 DOUDLE DIN WITH BURRBROWN DAC
FRONTS --- INFINITY REF COMPONENTS
REAR ------ OEM
SUB ------ INFINITY REF 1260SE
AMP------ JBL 1004e
MY SIMPLE SETUP
OLD SETUP
HU----- JVC KWR DOUDLE DIN WITH BURRBROWN DAC
REAR ------ OEM
AMP------ JBL 1004e
Better than my setup :D
that why i said look for used ones. You can get good deals wit higher end products . :)
Regarding the amp that you have mentioned in the previous, it does look VFM and powerful for the money you are paying.
Not a fan of sony amps though. If possible look at other options that Sony amps.
My first setup on my swift was a 4 channel sony amp (70w rms per channel) and pioneer speakers and pioneer HU (entry level) with jbl tube. But even though i replaced the pioneer speakers with some good ones (illusions Electra), there wasnt any difference.
But after i changed the sony amp to a kenwood 2 channel amp (with only 55W rms per channel), the speakers came alive and then i only i realized what i was missing for an year. After that i replaced the jbl tube with Illusion electra sub (used one) powered by a jvc 2 channel amp and then it all came together.
The last replacement was the HU to kenwood x694 (sourced from US through ebay global buy) and then only i knew the pleasure of listening to a true music system..
So when i bought the next, vehicle, i was very much aware what needs to be going in and what type of sound i needed. :)
Yes it is 2 years old but mot much used by the first owner and I have used for 2-3 months only.
It worked fine for me but as I have upgraded to a higher one....so puted it on sale.
I must say this will be VFM for you.
