audiodelic
HSU ULS-15
Driver
· 15? woofer!
· XBL2 TM linear motor technology
· +/- 33 mm Xmax
· Motor force (BL) stays within 2% over a very wide +/- 20 mm excursion
· Triple shorting rings for virtually non-existant flux modulation distortion
Amplifier
· Wireless connectivity using 2.4 Ghz wireless transmitter with four position channel selector switch!
· More inputs than any other sub we know of: Wireless L/R inputs, Balanced XLR inputs, unbalanced rca L/R inputs, and speaker level inputs
· 1000w RMS short-term power, our most powerful amplifier ever
· ULF Trim control that allows one to take advantage of room gain by adjusting the rolloff frequency anywhere between 16-50Hz
"So in many rooms people should get good response down to 10Hz with room gain factored in." - claimed by pete in their forum.
Specifications look intense considering its size.Reviews, measurements should be out shortly. What do you guys think, worth it ?
satish
Driver
· 15? woofer!
· +/- 33 mm Xmax
Amplifier
satish
