Power requirements and accessories
krishnamurthy
bangalore
I was told by my dealer that I require online UPS to handle the load of projector, subwoofer and AVR and to get 5 Ampere sockets for the same.
Would 1 KVA online UPS be sufficient?
You will need to provide specs or model details of ALL the equipment you plan to power through the UPS.
PSB X2T, Subseries 200 subwoofer, Marantz AVR 6009, Optoma H26
While 1 KVA online UPS should be okay for your setup, it would be better if you go with 2 KVA version. With 1 KVA, you will end up running at 80% to 90% of its capacity. In future, you may add a new component or upgrade an existing one to your AVR chain and the UPS shouldn't become the bottleneck for that.
