Prestige Turnberry - Help needed
Thanks everyone for their valuable suggestions. with every Change the performance is improving.
I haven't put the spikes till yet, but i'll try today evening.
Is it fine to have mat below the speakers.
Puneet
After moving speakers away from wall, the sound has improved in way that its not boomy.
but still seems like the 'back' sound is held by something.
it is very evident in Man of steel "Arcade" soundtrack.
Do you feel that some instruments and vocals are coming from a far distance?
If yes, then its actually a good thing and you are getting good soundstage depth
When you only some back sounds that is layering in the soundstage.
If for example you are listening to a live recording some instruments would be playing from the back of the vocalists and some from the front
If your setup is playing it that way you have some sound coming from a distance and some in front of speakers
I am sure a senior member can explain you with proper terms
Should be something like this in a layman's language,
The sound should come from an area approx. 1-2 ft above and about the same distance behind from in-between the top portion of the speakers. You would also get a feeling as if some live performance is going on, as if on a stage. You should also be in a position to distinguish between different instruments playing, their different locations and in some special cases, which ones are closer to the audience than others.
Saw your new speaker positioning. Still not ok! You HAVE to draw them out by @ 3 ft from the front wall. The toe-in provided seems ok. Your seating position should preferably be atleast 6 ft from the speakers.
Huge improvement after adding spikes and moving speakers away from walls.
i am very thankful to you all for the valuable suggestions.
:signthankspin:
now waiting for burn in.
you are welcome to audition speakers. we can decide on some day.
