sudhirpsg
Hi I was looking for a projector under 60000 and zeroed in on Epson TW650 it will be used in pitch dark conditions. Is this a good choice or I can get something else by stretching my budget a bit?
You can get better by stretching your budget..Hi I was looking for a projector under 60000 and zeroed in on Epson TW650 it will be used in pitch dark conditions. Is this a good choice or I can get something else by stretching my budget a bit?
Any suggestions sir ?You can get better by stretching your budget..
What's your Max stretch budget?Any suggestions sir ?
Max would be around 75000 sirWhat's your Max stretch budget?
It’s a great projector in 1080p and will come for 53-55k. If you are into 1080p don’t splurge more than that.Hi I was looking for a projector under 60000 and zeroed in on Epson TW650 it will be used in pitch dark conditions. Is this a good choice or I can get something else by stretching my budget a bit?
Yes sir. But i am just hesitant to spend 75K for 1080p projector. That is why i am pondering on it.Epson released TW750 as a replacement for 650.
Higher brightness and contract compared to 650.
Supports Miracast well
Thanks sir I am planning for 120 inch screen with throw distance of 14 feet will that be feasible ?All Epsons are very good. Yes, you can use the 650 in pitch dark.
You might get the Epson EH-TW5650 within 75k.
See if you can get a demo for both.
Other eqally important considerations are screen size, viewing distance and throw distance (projector to screen distance).
Not all projectors will fit every space.
As per www.projectorcentral.com, not possible with the 650 but possible with 5650.Thanks sir I am planning for 120 inch screen with throw distance of 14 feet will that be feasible ?
Sit the site says it is possible with 2.731m ~ 9 feet am i getting something wrong ?As per www.projectorcentral.com, not possible with the 650 but possible with 5650.
www.projectorcentral.com is by far the best site for projectors.
Epson Europe EH-TW650 Projection Calculator - Throw Distance and Screen Size
Find screen size and throw distance for the Epson Europe EH-TW650 projector.www.projectorcentral.com
Epson Europe EH-TW5650 Projection Calculator - Throw Distance and Screen Size
Find screen size and throw distance for the Epson Europe EH-TW5650 projector.www.projectorcentral.com
Confirmed on Epson Eu. The site has the calculator for 650 but not for the 5650
I meant maximum i would be able to stretch till 14Yes, possible. You had said 14 feet.
