Projectorscreens.in
Looking for recommendation for project screens. Got a quote of 13.5K for 110 motorized one with 2 feet border from this site.
Anyone has any feedback? The brand says Screen Technics, not sure if its the same screen technics of Australia
110" Motorised Projector Screen
I have a 2 nos. manual pull down screen technics projector screen and its fairly good. Don't know if they are the same from Australia
Thanks, I confirmed from Screen technics its not their brand but a chinese. Did you buy from projectorscreen? If yes, how was the experience?
Hey Madbullram, did you eventually buy it from them? I'm also looking for a screen and was considering projectorscreens.in
How was your experience if you did or if not then where did you eventually buy it from?
I'm using screen technics proj screen,It is ok.Cant say it's the best or even better.Bur for the price they offer is good.For living rooms it is ok. But for dedicated ht rooms pls go for Liberty Grandview they are good.
sorry i did not. Since I couldnt see the screen, i decided to go with a local vendor
