Proson Libra Speakers
prasanna.kole
bangalore
Hi All
one of the dealers in bangalore is offering Proson Libra speaker packages (653 and 655 series) which are made in sweden. as per dealer these speakers are better than Jamo or wharfdhale speakers for the same features. can you help me whether you have you have used these speakers and are better than other speakers.
653 compares well with Jamo 406
655 compares well of better with jamo hcs606
i have to close on speakers ASAP, but couldnt due to very less info available on proson libra
also the subwoofer used is JAudio. has anybody heard of Jaudio Subwoofers.
How did you find the sound? What all did you audition it with? Would like to have details of your audition.
hi prasanna.kole,
i found this (googled)
Manufacturer's Description of Proson Libra loudspeakers
To build a speaker that sounds good is not difficult. To build cheap speakers are not difficult either. But to combine these two things are not that easy. This is Proson's biggest strength. Now Proson can offer a series with an attractive look and a very low price, with very few compromises. Though Libra is Proson's most simple series, it has very good driver units and a solid cabinet. If you're not sure, please compare them with other "low price" speakers and you will find that it's only the price that is low with the Proson brand.
Hi All
i auditioned these speakers but due to acoustic issues (which i shouldnt blame speaker for that) i cannot fully judge the speaker. the 655 series sound good. it was good on music with bass and treble being good.
it had 250 watt jaudio subwoofer. actually 655 series has 1 2.5 inch tweeter 2 x 4 inch midrange and 2 x 6.5 inch bass. its 3 way speaker. i wanted input whether somebody has those speakers and used in very good acoustic conditions.
prasanna
hi
how are proson speakers quality & performence. where can i see the demo of the speakers in bangalore. could you let me know more on this speakers
regards
giri prasad
The contact is Alpha Enterprises in triveni road, Yeswntpur.
Contact 9886066021
He has 5.1 set up starting from 27.5 k and Wharf lookalike .
Have nnot got time to audition it yet.
