PSB Alpha B1 - best price
well surprisingly most speakers upto the 80k - 100k mark have pretty crappy crossover components.
Thats why a crossover upgrade can do a world of good. However its not cheap and can cost upward of 5-7.5k on the mod.
Even the crappiest components can last for years. I have a vintage Pioneer which has one hell of a crappy crossover ... 20 years and still going strong..
The world of difference it can bring to the same loudspekaer is phenomenal.
FM viki can give testimony to this :indifferent14:
There is a saying. If it ain't broke dont fix it.
You like the sound of the Titans .... Enjoy them .... :yahoo::yahoo::yahoo:
There are a lot of folks who have done Crossover upgrades on speakrs like Totem, Klipsch etc .... a google search will give you results....
It will set your brain into overdrive.
Looking at the cross-over i am sure its components should be atleast 10% tolerances for inductors, capacitors and even resistors. Hence upgrade will be difficult unless you have the original circuit diagram with the component values.
Sometimes yes,sometimes no.eg.CA S30 got 5star & praise from most of the listeners,still it uses basic CO.-
As long as the final sound is good,do we really have to consider?
Well Tannoy F1 has little crossover I thing.:rolleyes:
See B&W DM303 CO-
These cross-over looks much better made and also uses a better gauge inductor, polyester capacitor and a wire wound resistor instead of a fusible one in the PSB. Also the wire gauge look quite decent.
Lakozy of course, Not sure where it is exactly located in Mumbai. Better ask mpw or Denom both have been there recently.
Girgaon Chaupaty,Mumbai.Opposite Seashore :D.
Lakozy Mansion, 21-Chowpatty Seaface,
Mumbai 400 007, India.
Tel: 91 - 22 -23697001/2, 23692213
Fax: 91-22-23698001
