Q Acoustic s2001 5.1 Home Cinema for Yamaha AVR?
If you are looking out for something which will do good justice to movies, music and gaming ...the Boston Acoustics Soundware XS 5.1 speakers are your best bet and within budget....HiFiMart sells the same for 24k. I did audition these speakers on a Marantz SR AVR and they really rock for the size and price...better than Bose Acoustic Mass etc...value for money.
With the budget you have, you can even go for Bookshelf speakers....There are Bostons available on Hifi Mart even Floor Standers with a good more powerful sub. End of the day it depends on what appeals to you and your wallet.
Hope this helps.
Re: Q Acoustics s200i 5.1 Home Cinema for Yamaha AVR?
Hi Nanu,
How much you paid, and from where you got them.
83K from here:
http://shop.technoguru.in/packages/q-acoustics-2000i-5-1-cinema-package/p-0816448-2374644549-cat.html#variant_id=0816448-2374644549
Got the following in fact:
2 x Pairs 2010i Speakers
1 x 2000Ci Centre Speaker
1 x 2070Si Subwoofer
3 X Wall Mounts (2 for front & 1 for Centre)
AudioLink Speaker Cable - 50 Mtrs
Chord - Subwoofer Cable - 01 No.
2010i Speaker Specifications:
Enclosure type: 2-way reflex
Bass Unit: 100mm
Treble Unit: 25mm
Frequency Response: 68Hz - 22kHz
Nominal Impedance: 6ohm
Minimum Impedance: 4ohm
Sensitivity: 86dB
Recommended Power: 15 - 75w
Crossover Frequency: 2.8kHz
Dimensions H/D/W mm: 234.5 x 203 x 150
Weight: 3.5kg
Sold in: Pairs
Warranty: 5 Years
2000Ci Speaker Specifications:
Bass Unit: 2 x 100mm
Treble Unit: 25mm
Frequency Response: 75Hz - 22kHz
Minimum Impedance: 4.4ohm
Sensitivity: 89dB
Recommended Power: 25 - 100w
Crossover Frequency: 2.7kHz
Dimensions H/D/W mm: 160 x 203 x 430
Weight: 6kg
Sold in: Single
Warranty: 5 Years
2070Si Sub-woofer Specifications:
Enclosure type: Ported
Bass Unit: 2 x 170mm
Amplified Power: 150W rms
Crossover Frequency: 50Hz - 150Hz (var)
Dimensions H/D/W mm: 425 x 560 x 195
Weight: 14.6kg
Sold in: Single
Warranty: 2 Years
As mentioned earlier, I am to pair this with the Yamaha RX-v375.
Got the speakers last week, but had been busy.
They are much bigger than I thought they would be, but thats fine
Just connected them temporarily for now to test them, and used the YPAO and it all seems to be okay for now. Will position them where I need them to be tomorrow and will re-calibrate them. Just tested a bit of music to setup the Sub, and tested RUSH and sme other Blu-Ray for the movies. I am sure it will take me sometime get it all set upo right.
Any tips on setting up...?
Thanks a for all the help.
As for the TV I have decided to hold onto that thought for another week or 10 days or so, will decide then, right now I am just overly joyed with these speakers.
