quick and dirty speaker stands
without sand fill also it doesnt vibrate. but filling with sand will ensure perfect rigidity. depends of the speaker box weight.
where from procured the rod...is it from the plumbing store..
the water pipes having thereads...that thing?
or something else
thanks
threaded rods were custom done from hw/steel fabrication workshop. buy a rod of 10mm-12mm and they can do threading on it.
water pipes dont have any threading. using washers and bolts, threaded rod will hold the top and bottom wood planks together, with pipe around it.
I like the idea. Have always intended to improve on my pile-of-books stands for my monitors. Actually, sonically, the books are probably good, but looks-wise, not good.
re the rods... in UK, something called studding is available, which is rod threaded for its whole length. You just cut it as you want it. Would be ideal for this. Is it available here?
