Hi all, speaker resistance and power raitings of amps have always been something i am never rock solid on, i should really know more!
I have 2 big JBL JRX125's. they run the following spex.
Nominal Impedance : 4 ohms
Recommended Amplifier Power : 500 W to 1000 W into 4 ohms
I currently run these with a QSC GX5 amplifier and have never had an issue. they were sold as a package, so i assumed they were paired appropriately.
QSC settings...
8 ohms/1 kHz (both channels driven) 500 W
4 ohms/1 kHz (both channels driven) 700 W <-- i believe this is the setting the system is operation at.
My question is, will these speakers be a good pair if used with a
Behringer EUROPOWER PMP4000? This is a mixer that also has an amp built in.EUROPOWER PMP4000 Output Power
RMS @ 1% THD, both channels driven:
8? per channel: 300W
4? per channel: 600W
RMS @ 1% THD, bridged mode: 8? 1200W
Peak Power, both channels driven:
8? per channel: 400W
4? per channel: 800W
Peak Power, bridged mode: 8? 1600W
Please let me know your advice, and how you concluded it.
THANK YOU IN ADVANCE! cheers.hyeah:
QSC settings...
