Oops! while building my tube amp kit, I made a mistake in not aligning the height of larger caps with smaller ones - the larger caps were meant to be pushed from the solder side of the pcb upto a certain height only. (See image)
Now they they stick above the height of the valve sockets. Unfortunately I nipped the leads very close to the pcb, so even if I de-solder them the leads will not longer be long enough to re-align them to a lower height.
How do I recover from this now? Can I solder the nipped leads back to lengthen them? Or is it a strict no-no?
--G0bble
--G0bble
