Re: SVS woofer help
Ghostrider
India
Need help for my svs woofer,
somehow one of the rca female connector on the board has been chipped off, may be due to its age or at some point connector bend or something.
is it easy to open the board or can anyone recommend some place in mumbai to get it fixed.
As seen it seems board needs to be open and new connector needs to be soldered or so.
If it is in warranty then it can be taken care off.
Else pls call the SVS India dealer, Mr. Samay +91 98 10 154288 and ask his opinion.
You can also email SVS directly as a final option and they will promptly get back to you.
Regards.
Regards.
Alrite thanks, it’s not in warranty
That’s of pc12 nsd, cylindrical woofer
