Rear surround and center channel help needed
Michelangalo
Pune
Hello,
I am looking for rear surrounds and center channel preferably used as I am tight on budget.
Preferable options:
Rear surround- Polk Rtia A3
Cente- Polk Csi A6/ A4
Open to other options as well if it goes well with the below setup.
Current setup:
Denon AVR 2600H
Front- Polk Rti a7
Sub woofer- Bic America Pl200
Any leads would be appreciated.
Thanks!
Hello,
Preferable options:
Current setup:
Denon AVR 2600H
Front- Polk Rti a7
Thanks!
There is no need to look at other options. Go for the same series in Polk.
Csi a6 is monster and fxia4 is very good for rear channel. You cannot go wrong with them
FXi A4 is a nipple/dipole. As per my research it's suitable on side wall and gives more a disperse sound. Most of the users have recom need monopole for rear surround which can go on the back wall.
I think Polk RTiA1 is still available on Classified section with decent price tag. You may check it. RTiA 1 may work very well with your setup.
