Recommendation for side channel speakers.
Czar
Present setup:
Marantz 6009
B&W 683 S2 FS
Wharf 10.2 Rear
B&W sub HTM61 S2 + Wharf sub SPC 10
B&W center ASM10CM
please advice for making it 7.1 channel, thanks
Depending on if you are going to use the 2 remaining channels as front height speakers or extended rear surrounds, you need to select the kind of speakers....
Look at Jamo C series, Taga B40s / S40s, BIC America (Acoustech series), Wharfedale 220s / 230s.
ok thanks... like the in ceiling option... can make it 9.1 too.. so front height plus was thinking side channel...
NHT superzeros are one of the smallest sized with amazing sound. No bass reflex ports so would best suit for surrounds. Bic Acoustech are also great option.
