Hallo everybody,
I have a problem with my BNS 384 speakers (bought in the 80's)
It are threeway closed box floor standing speakers
Crossover 500/5000Hz
Impedance: 8 ohm
freshrate: 28-22000Hz
+/-3dB: 40-20000Hz
sensitivity: 89dB
Piek power: 130 Watt
Power rating 20-100Watt
One of the bas drivers (woofer) suddenly stopped producing any sound.
There are no defects to see and the driver can easily been moved by hand, it also doesnot make any sound when doing so. The crossover is ok (checked)
I cannot find out what brand it is, perhaps enyone can help me by that.
It is a 263mm (10 inch) bas woofer
pitch 253mm (8X5mm holes)
The marks on the back (of the magnet) of the driver are:
M25WN-41
111530-6 8 (ohm)
Can I still buy a replacement driver for this speaker or what to do else?
Please advise!
Impedance: 8 ohm
+/-3dB: 40-20000Hz
sensitivity: 89dB
M25WN-41
111530-6 8 (ohm)
Please advise!
