raja_mastana
My 6 years old Audioengine 5 also developed problems like crackle, massive pops and "blow into microphone" sounds
When we switch on the unit, there is no noise or crackle. But as soon as a song/audio is played, the above mentioned issues comes up.
As there is no Audioengine support in India, I got it repaired from other sources. Here are some details which may help other A5 users.
The below is my assumption - please correct if you see a mistake.
There are two circuit boards in the audioengine 5. The left one seems like the preamp. It has two voltage regulators, some 8-9 solid caps and other caps. The right one may be the power amp (caps like 475j 100v are present here).
I can see repair was carried on the left board only. The right board is untouched.
Looks like 4 capacitors are changed and a resistor also added.
