Req help with Front Speakers
cyberbaba
Malad - Mumbai
Hi Guys!
I am new to this forum and not a big audiophile at all hence wanted some help selecting a simple not a very high end budget set of front speakers. I have a Yamah RX-V550 amp. My budget is 6-8k. The fronts can either Bookshelf or Sats that fine but they need to be wall mounted. If you guys can suggest a few models and dealers in Mumbai it would be great.
Cheers!
Nik
Hi Guys!
Cheers!
Nik
for Yam you can opt for-
MS 902- 12k
Wharf 9.1(10)- 12k
Mission M30i - 8k
all these are available @ Allince4 Andheri,D.N.nagar
Jamo sat-7.5k @ The shop next to Alliance.
MS 902- 12k
Wharf 9.1(10)- 12k
Mission M30i - 8k
Thnx for the suggestion mate, unfortunately I called them up and they dont have the Mission as the others are out of my budget.
Any other suggestions. Thanks
