Role of USB DAC while playing audio via youtube and FM
You mean if FM played on mobile then DAC would come in picture. If yes then conflicting with z@m's view.
MaSh and z@m:
your opinion is based on interpretation or you studied circuit flow of mobile DAC?
Yes you will need a USB DAC if you connect your Mobile via its USB port for FM, which you have mentioned in the post quoted below. If you connect a 3.5mm stereo cable to your mobile's headphone jack, then No, you do not need a DAC.
Thanks ... FM I meant while playing FM from mobile and mobile is connected via USB DAC
Yes, when connecting to the Mobile USB, you will need a DAC.
MaSh
