keith_correa
Anyone tried these [https://github.com/dynobot/Linux-Audio-Adjustments]?
I just tried - no sign in needed.Hmmm.... needs sign in
Ropieee is ArchLinux based AFAIK so you should go here: https://github.com/dynobot/Arch-Linux-Audio-RPiI could now after removing the extra characters. By the way any idea if I can use this install on my Roon bridge transport RopieeeXL on 3B+ as I could not find the required info on the site. These are the pre-requisites.
Should work on any SBC running Debian based OS, has been tested on:
- Raspberry Pi (v1) model B
- Raspberry Pi 2 model B
- Raspberry Pi 3 model B and B+
- Allo Sparky
- ASUS Tinkerboard
- Odroid C2
Thanks for the "heads-up" "Meerkat" Keith!!<snip> I backed off quickly because I'm in too many other holes right now - don't need another. <snip> But I can say one thing, the same sort of tweaks work very well for bettering audio on Windows so...
ROFL!"Meerkat" Keith!!
It did something not sure what thoughThis looks interesting. @manniraj waiting for your views.
audiophilestyle.com
Not quite. I said that as Ropieee is purposefully built on the OS, the underlying OS is probably already optimized for audio with tweaks already made for non-variables.<snip>but I guess Keith mentioned that as I use the USB out from my Pi with RopieeeXL OS does not help much.<snip>
