karthi1000
Hi folks the long wait is over to get my hands on rythmik fv15hp..
thanks to ashish avenue sound who make this happen and also denom who gave the information and fellow user sowhatxyz.. I am in mood to add another sub to my ht setup for the past 6 months.. after gaining some knowledge ( i think so):lol:about servo sub i think i can go for rythmik and ordered through avenue sound ... 3 months after i ordered then came the tracking number
i have been tracking the courier from mumbai to trichy eagerly .On tuesday I find that rythmik sub arrived at my city hub.. I heard that it was 110 lbs equals to 50 kg so i went with my assistant to pick that from the couriour hub ,,,,not able to wait to deliver it to my home., To my surprise the package is sooooo big two fellows cant lift nor it can be transported in innova with back seat folded , so i left it there to deliver via their lorry . Back at home I managed four personns ready to lift the package to my room upstairs. After two hours the courior lorry came and they kept the parcel in the door steps and they are in real hurry to get my sign and vanish
but i told them don't panic its enough to keep it at the doorstep itself I will managae to lift it to my upstairs room ,, then only they became calm
hyeah: finally we manage to lift the parcel to my room
then with the help of two i unpack it and then connected to my setup
you can see the pics its like a mini floor stander next to my B&W 683.
i am using line in input no peq , volume 50% ,cut of frequeny at avr 100hz all other spks 80 hz one port in rythmik.... After initial calibrations i measured the output
oh my god for so many years i am living without 15-22 hz
bass is tight i can feel the air movement
i am already using velodyne spl 1200., Adding rythmik eases out velodyne . the room fills with subsonic energy easily.. Velodyne alone cant reach that 80 db at 15 hz but the brutal combination produces the effect i like.
The real beauty is 15-18 hz boost up u can see that from the graphs . first one velodyne alone second velodyne plus rythmik :clapping:
there is 80 db at 15 hz unbelivable out put
i was in dilemma to combine ported with sealed sub that too with different companies , but now i am happy and i will definitively recommend this sub who wants tight chest pounding subsonic energy
here is a pict of size comparison
PARDON ME if anything wrong in this post , since i am not an expert
