Screen Controlled by projector
AV55
is anyone using motorized screen which is controlled (UP/Down) using the 12V triggering output of the projector? Please share your experience. Thanks
I didnt know we had that kinda technology :D
thanks for updating me with that ... I will search and get to know more about this :)
This is a feature of most of the high end projectors and AVR. I have Epson TW 8200 which has this feature. Currently I use a remote to lower and raise motorised screen. I am looking for a compatible transmitter (attached to projector) and receiver which can replace the remote.
Cool :cool:
Which Screen are you using..
I am searching for Good Screen for TW8200 around 10-15 k..
it will be helpful if you can suggest.
