hi,
I got those stands from Magma. Made to order The top plate is slightly wider and deeper than the speaker and it has skirting screws.
Hi have you skrewed your bookshelf to the topplate or glued.
can you please send me the pics of your bookshelfs mounted to stand so that i can have a better understanding of how to go about, if its glued then no issues/
