Selection of Sub
Sachin_Blr
Dear friends,
I am doing a selection of Subs between Jamo J10 and ELAC SUB50.
Can you recommend one for room size 19'x17' with ceiling going upto 15'.
Sachin
Dear friends,
Sachin
Not sure about the cost of Jamo J10 or ELAC SUB50. Whats your budget ?
Arjun
Would suggest velodyne impact 12 as your room is very large. Later you can add one more sub which will result in sufficient bass throughout. You can also check svs but your budget will overshoot badly. If you cannot extend budget then also look at boston acoustics asw650 which is decent for its price
