Should Amplifiers Be Transparent?
kanwar
Banned
Banned
Earth
Apparently, a higher damping factor would need other changes in the design which would alter the sound signature.
Regards.
Akshay
Honestly an amplifier must be TRANSPARENT and should not have any sort of sonic signature on the music output. If you say it has a particular sonic signature then it means there is an ingress in its sound character. An amplifier must be neutral and should not in any way add any sort of "color or signature" to the signal it is reproducing in amplified form.
regards,
Kanwar
Re: Puriss A1000A. Class A amp for serious listening
sorry kanwar
to that i do not agree
if all amps had the same neutral signature there would be no need to have so many brands would there
if God would have created everyones tastes the same - life would be mechanical
the fun is the flavour and the differnt likes and dislikes of people
Music is subjective and so is what one likes or doesnt
Hence there is a demand for differnt amps with differnt sonic sigantures
for example i hate neutral amps
In fact one of the amps i use is known to be colored! and i like it that way!
regards,
Kanwar
Well, thats why sound is said to be a black art. 2 amps having the same tech specs can sound very different when driving the same pair of speakers. Thats also the reason why you must extensively audition before setting up a dream system. You may be using the best of components, but the combination may not be the best.
When you say 2 amps can sound different with same specs on same speakers it means either one of them is not transparent and adding the so called signature to the sound itself.;)
Hi Kanwar,
This is all theoretically perfect and in fact, most DBTs show that people can't tell amplifiers apart.
However, the entire hi fi amplifier industry could potentially shut down if people didn't claim that their amplifier wasn't doing something special or different. Why would anyone buy a Wavac at $350,000 (with measurements worse than a transistor radio) when they could pick up a 1000 wpc B & O Icepower module at $300 which should theoretically work for all applications?
What is the reference for "transparent"?
There are series of tests which should be performed including TIM[Transient Inter Modulation] with pink noise and evaluated on the basis of crest factor, SMTPE IMD test 60Hz +6.5khz 2:1, Ingress Test using multi tone burst evaluated using spectrum analyzer, Slew rate test and reactive load handling are few of the known standards which are often used by manufacturers for establishing neutral character of so called sonic signature of an amplifier.
Hi Kanwar,
Yes i agree. DBTs are more than often a marketing gimmick which only gives you a forced impression that "mine is better". I know that this kind of market is full of such amplifiers having known sonic characters with price ranging from thousands to lakhs of rupees, which are often used for selling the product to end users.
Measuring an equipment on the basis of well laid standards and then obtaining a factual piece of information is not at all theoretical , its a scientific evaluation.:)
Kanwar
This is a DBT.
What is a blind ABX test ? - Hydrogenaudio Forums
Don't understand how it is a marketing gimmick!
Yes, its DBT no doubt, If done on serious basis its valuable but when the discerning listeners are unable to reach an argument/valid statement among themselves that if a " known " subjective or objective difference persists or not, what shall be the weightage of such test?
If you go through reviews of products by a popular magazine called Stereophile, you will feel amazed at them because they also do DBTs and bias their opinions on donations they receive from the manufacturers of high end equipment they listen when comparing them with competitors products. The products they evaluate and rate at topmost is the one whose manufacturer has paid highest perks to them.
There is a another very neutral magazine goes by the name Audio Technology who publish measurements which are very factual and are least biased. Having tested variety of professional gear myself i have seen the measurements i get co-relates with them in very nice way.
In that sense DBT is a clever marketing gimmick nowadays.
Checkout the propaganda which was exposed:
http://www.high-endaudio.com/RR-STEREOPHILE.html
Hi Kanwar,
This question may sound personal. Though thats not my intention, could you please let me know how many and which amplifiers have you owned heard and enjoyed in the past.
Hi Kanwar,
Hi Akshay
Having reviewed Bryston 7B, Arcam FJM P1, Ayre Mx-R to name a few which are mostly monoblocks and which i really like to listen. Apart from that i am also a professional amplifier designer myself and research analyst from past one decade.
Below is pic of my recent 8KW[4000WRMS per channel] Alpha amp featuring all dual mono construction.
Kanwar
Hi Akshay
Kanwar
Hi Kanwar, Could you please explain the design type. what bias current have you used. what is the rail volatge and o/p transistors. How many pairs of o/p transistors have you used. what are the distortion levels. And how transparent is it.
Regards.
Akshay
Hi Akshay
Kanwar
Which amp do you love most of the ones you quoted. Which is your favourite?And why.
Regards.
Akshay
Regards.
Akshay
Hi Akshay,
The design of Alpha is complementary Grounded Emitter Floating rails, 3-Stage Deep Darlington[Pre-driver->Driver->output] pushpull with 3-step Hi-efficiency Class-H switching stage. The output transistors are Fairchild FJA4312/4313 devices biased in modest Class-AB mode around 40mA per device. Total 52 Devices are in the output section of both channels. This amplifier is intended for professional installations in sound reinforcements only.
Owing to class-H operation the rail voltage is +/-60 LO,+/-120 MID & +/-180VDC HI
THD 1W is 0.001% @1khz
THD @ 1dB below Clipping is 0.05% at fully loaded @ 2ohms @ 1khz.
SMTPE IMD is below 0.05%.
SNR=100dB
PCB= 2.6mm Double layer Fiber Epoxy PTH with 75micron copper thickness
Slew Rate is 75V/uS
Filter storage Capacitors= 36 X 18000MFD/65V each
Full Power bandwidth is 20hz-40kHz
TIM is negligible owing to 12dB crest Factor average to peak ratio.
Damping factor is 1200
Reactive load handling is stable upto 60degrees of lead or lag with either inductive or capacitive loads.
Protection= Thermal, Open circuit, HF protection, Short-circuit, Clip limiter, DC-Offset protection using Traic crowbar.
Regards.
Akshay
I Like Bryston 7B the most.:)
Reason: It is capable of driving highly reactive and low impedance loads[speaker] with quite an ease, thanxz to its quad complementary outputstage.
Kanwar
sorry kanwar
Sorry to say:
Then you are not listening to the "actual music content", you are listening to the "Recipe" cooked by the colored amplifier.:)
An amplifier should "TEND" to be neutral than only you can get the essence of real music information.;)
Kanwar
Actually, FWIW, if an amplifier colors the sound and I like the color then I say more power to the colored amplifier
BTW, Kanwar, this is OT but I really like the way your Alpha looks. Wow! Though, when I showed the pic. to my wife she made a face. Women!!!
Holi the festival of colors is coming, so happy Holi to all, enjoy coloration in amplifiers also[just joking]:ohyeah:
Kanwar
Sorry to say:
Kanwar
hmm
and you decide what recipe i like or for that matter what everyone should like?
fantastic.
there is no definition of essence of music information
hmmm. also what would you say about musicians who have the same amp as i.
they listen to their creations on this amp
You are saying they produce transparent music and then have it colored by the amp
brilliant!
music is music my dear friend thats why its subjective
as i said no on can decide or state which amplifier captures the true essence of music
merely because that true essence is interpreted differently by different individuals
there is rarely something definitive in audio
what floats my boat may drown yours
There is nothing called a neutral component..they all add "colour".
An regarding measurements...less said the better..we do not even know how to measure music..music is not in pink/white noise.
hmm
fantastic.
brilliant!
Deciding factor is your conscience not me, If you like coloration of specific taste then its your liking not mine.:)
I always prefer an equipment should always be neutral.
There are enough and more ways to measure musical content across the spectrum- in a non pink noise manner. And when you talk of your ear as the ultimate measuring instrument, that is flawed too- the ear is far less accurate than measuring equipment used in the lab.
And there are neutral components available that don't act as expensive EQ units. It's a different matter (and possibly valid, too!) that you may not like that sound.
