should i go for a monitor upgrade???
agent47er
noida, india
hi there
i use my pc for image editing and modelling(mostly on 3ds max) and was wandering if it would be wise to replace my existing dell s2210 with a u2410 or some other such monitor... Ho much of a differnce can it make???
From my experience of working in animation, I would suggest you add another monitor (same one is perfect) and get all the screen real-estate you need. It will make a world of difference since you will be able to keep all your windows spread out nicely.
make it dual monitor as suggested.. will be more useful as per your job mentioned.
if you are unable to find the excat model probably then you can go for upgrade..
but from 22 to 24 would not be a wise investment...
27"-S27A550H LED : HDMi 1920 X 1080 - 2 ms 19500 this is the biggest monitor available.. 27 from samsung led.. however same price or a bit more you can get a toshiba 32inch lcd tv... so either dont upgrade else go for straight 32...
22-24 you wont notice diffrence and it will look like negligible after few days of usage..
