Should Polk s35 Center speaker be used with IndiqAudio Fronts?
rshri
Noida
Thinking of having this 5.1 setup for a 10ft X 11 ft closed room-
Fronts - IndiqAudio Diamond/Platinum Mishra
Center - Polk s35
Rears - Polk Owm3
Sub - QAcoustic QB12
Will it be weird to mix IndiqAudio and Polk for LCR like that?
Dont want to use IndiqAudio Center (Universal Aakar) because they will be too big and "Boxy" for my setup
Ideally fronts and centre should be from the same brand and model.
But we hardly live in an ideal world.
A reasonable match of driver size and material would be good though. Indiq centre and selected centre.
Center - Polk s35
Rears - Polk Owm3
Hi @rshri
I'm currently using Indiqaudio diamond mishra as LCR and wharfadele 11.2 as rear. when I replace the front with the rear there is some difference in tonal mismatch I can hear. You can discuss with Amit and do some custom sizes if possible.
